I had my 4g63t motor sit for two years, without any cranking. Never burned oil or puffed anything other than stoich,10.5:1 at WOT. It started up and puffed blue within a few minutes. Huge cloud behind the car and my parking areas.
I freaked, but said f*** it. Must be sweating seal in the turbo that relaxed, or seals let oil down the valves. I only ran Mobil 1 5w30 synthetic oil in the motor.
Put my foot on the accelerator, brought the RPM up slowly to 2500-3000 RPM and let it sit there for a few minutes.
Cloud got bigger, then slowly got better, and eventually was completely gone. Oil had to work out of the head, turbo, catalytic .. or wherever it was.
If the tech is willing to run the engine this way out back of the shop, it's a few minutes worth of work to see what happens.
I read most of the postings, but if the turbo from your last motor was used (and not smoking), then seals/rings, would be my thoughts.
Not the end of the world if seals are bad, and the importer is willing to cover the shop installing new ones, and a new valve cover gasket w/spark plug center area gaskets.
Swap the PCV valves between the motors, or better yet, spring for the $7 part anyways. These are items worth switching out now anyways.
