idle 4 k after manifold and throttle changed. (need help)
With adjusting the TPS you can leave the car off with the key in the on position. are you using a data logger? May be the easiest way. With the Biss screw i don't belive even adjusted all the way in it would hit 4k. If its not the TPS, i'd do a boost leak test and make sure the FIAV isnt leaking.
Jesse
kooter
carpentersville, IL
ok have checked tps and isc both are not dead on but very close to what the vfaq says.
about to jumper wires and attempt to set biss according to vfaq page.
no logger just using multi meter and jumper wires
kooter
carpentersville, IL
switched throttle bodies back to original.
problem is gone.
only thing I can say I noticed was the tps on the original tbody has only three pins, the pc'ed newer one has 4 pin.
AnotherNewb
Orlando, FL
4 pin tps is a 2g I belive since they had the throttle closed switch in the tps instead of on the other side. If it was me I would block off the fiav and put it back on with the correct tps.
