ApexHunter
Probably the right call. Maybe it would have been fine, maybe not. After all the hard work you've done, it would really suck to find yourself in a desperate spot where you have no choice but to use the careless asshole tow guy and/or retard repair shop, because you need to be at work Monday morning. I went from OC to Mammoth a few years ago and had two separate incidents on that trip. This was in a stock 1995 Honda Accord as well, and the thing was tip top before the trip. Man it sucked.
RE: Water Wetter. Reason #1 WW works well is it acts as a corrosion inhibitor so you can use 100% distilled. Straight water has ~20% more heat capacity than 50/50, so those big temp drops they advertise on the bottle is assuming you're using 100% water. The other important part of the equation is heat transfer. Another problem with straight water is that it has a lot of surface tension and the heat has some difficulty being transferred from the water. The WW has really good transfer properties and helps the water with heat transfer. Obviously straight water has a lower boiling point than a glycol mix, and the WW helps bump that up. That and increasing system pressure. WW is not as effective if you are using a glycol mix, but will probably help a few degrees.
