4Grim
Quoting bazeng:
Use the studs mate. That way you wont wear out the thread in the head.
The washers are also required (rubber coated). The nuts too.
You will need a different valve cover gasket (from Hyundai).
Keep in mind also, not all spark plug covers will fit, the Hyundai ones have a tiny difference in the bend near the oil cap.
I got my hyundai valve cover from a 99 Sonata in a salvage yard. I read this thread stating studs and nuts..but the ones I pulled off the Sonata were bolts, but with a thicker base with about half a inch of thread. It fits fairly well..but like what Bazeng stated, the upper left corner of the valve cover and the upper right don't line up center with the Mitsu head. I had to grind down the center base of the bolts a little to get the bolt to thread into the head..but it was a easy solution. It was weired..only issues where those 2 bolt holes, all the rest sit perfect.
Here is a pic of the Hyundai VC..stripped the original black paint and repainted it gunmetal.
