Hows your meth setup
EMX5636
Bucks County, PA
Wiring is pretty easy. Instead of wiring the controller output or Hobbs switch to the pump relay, you wire one of the DSMLink outputs to it. Then you tell it when to turn on/off, disable it, etc.
Battery to 30 on relay.
DSMLink output to 85 or 86
Ground to the opposite above
Power to the pump (and solenoid if running one) to Pin 87 on the relay
