Help with knock. (Making progress)
Yes, adjusting an SAFC can indirectly affect timing. If you're making large changes, adding airflow can put you into a lower timing map, and subtracting airflow can put you into a higher timing map.
James
Port richey Florida
Timing is set at 5, boost is WG pressure so about 10 psi. No change today. And I'm not using a 1g Maf I'm using a 2g. Getting the Safc was the suggestion from this very forum lol. 550cc inj 2g Maf and Safc to get the small tweaking between the two.
ktmrider
Tempe, AZ
Quoting James:
Yes that's why I said TEL/DSM/GVR4.
Interweb is just too saturated with heresay and bad advice. Heck the rumor for most Subaru and EVO site users is 20% aren't old enough to drive and another 40% don't own a vehicle and/or lie about mods. Actual owners generally have no clue how to even wrench. Many go on other sites then regurgitate info elsewhere to "appear" legit. And onward.
Put your car back to stock as much as possible ( injectors, MAF, ECU, boost, etc ). Get it running right then and only then MOD it right, ie Link or custom chip and related support items.
James
Port richey Florida
Posted a WTB for socketed EPROM hopefully with a chip already fitting my needs
Who's the big name chip maker these days? Noticed keydiver no longer makes em when I visited his site the other day.
matt92vr4
Venice, FL
I don't think the SAFC is the problem here. Do you have a WB o2 sensor? I'd like to see your AFR when it's knocking 45.
James
Port richey Florida
I did. I had a PLX setup but the black box that goes to the sensor and to the gauge busted. I don't think it's my AFR since I can do a WOT pull with 0-5 counts of knock. I'm looking for a decent arm wideband setup ATM
James
Port richey Florida
Made a little progress. Did some freereving testing today. Slowly reving from idle up to 3k. Looking at the logger I noticed that every time the knock jumped to 40+ at 1900rpms every time. And dropped back to 0 at 2500rpms.
I feel as if this is a pretty big discovery in the problem.
Note: so people don't think I'm just asking for help and not doing any thing. I'm talking to a guy about a EPROM ECU with a chip for my setup, talking to a friend about a fuelpump and AFPR, and a third guy about a wideband setup.
Now I just need a 4th to hand me a $1000 check.
matt92vr4
Venice, FL
Glad you are making progress. If you are willing to drop a grand, go with the ECMLINK v3.
Now I'd like to see some loaded WOT pulls starting above 2500rpm to see what happens.
James
Port richey Florida
Link isn't on the list of plans for his car. It's not getting any bigger than the 14b and it will probably never see about 16psi.
Before i can do a real Wot pull I need to either...
A) get my fuel mods and turn up the boost to alleviate boost creep/fuel cut
B) pull the o2 and port it out
Now I've gotten pretty good and feathering the gas to redline to keep the boost around 10-12psi but I don't think that's going to give the most accurate readings
matt92vr4
Venice, FL
Even with a stock turbo, a properly tuned speed density system will produce significant HP gains.
I personally feel a MAF based system is better for a daily driver, and is the reason I ran SD in 1051 and a 2gMaf in 503. Both had ECMlink V3. Less constant tweaking needed. You won't make enough extra power on a small turbo to be worth the hassle, IMO.
That said, ECMlink would help tons with tuning regardless of what type of air metering you run, whether small turbo or large. I would try to find a used V2 as they can be had just over $200 usually.
5OF2k
colorado springs, colorado
Personally, I've never had issues with DD'ing my car, which is SD tuned on AEM, and I drive upwards of 60miles a day... I never have to tweak it either, and the only times I've even connected it to a laptop were to log, and to check the idle parameters and cold-start parameters.... But thats just me I suppose....?? /ubbthreads/images/graemlins/dunno.gif
-Jake
matt92vr4
Venice, FL
That's interesting WOP, I have the exact opposite experience with SD builds. They always run great and put down about 15% more HP than MAF builds with the same goodies. I've only done 2 ECMLINK though, the rest of mine have been AEM and I had an AWD dyno so that may have helped a bit.
Don't get me wrong. I love SD. 1051 runs great with it and I'm sure DDing with it would be fine, but I constantly tinker with my VE map. Maybe I should have tried it on 503 before I sold it. All I needed was a IAT sensor since I already had a MAP and WB for logging. Either way, for the OP, I think that's a bit out there. Not only would he need V3, he would also need to invest in a MAP/IAT and get it all wired up. He already has a 2gMaf, so in my mind, it's better to get it running right with that before moving on.
matt92vr4
Venice, FL
Are you using the AFC Neo? I just remembered when they first came out they were all messed up. If you are using one from the original batch they can blow up your engine. I lost 3 engines from these POS's.
James
Port richey Florida
New ECU and chip is installed! Knock is all gone. Ran her up to redline with no problem /ubbthreads/images/graemlins/smile.gif
Fuel pump and AFPR are on the way also! Next paycheck is wideband and MBC.
