help! no start...
b00st33d
Central, CA
^^^ bumping this thread up. I have been busy with school project/finals and been putting overtime at work.
So I bought a logger as advised. Palm M500 and MMCd software. When I plug the logger in and put the key on the start position. The numbers would just come up on the screen looping over and over. Is there a way to stop it or is it suppose to log some numbers and give you values?
AnotherNewb
Orlando, FL
Do you have the car turned on when the numbers are looping? I had a copy of palm n stein on a purchased logger that did the same thing. I would try reloading MMCd on your palm and see if that fixes it, if you got a copy of it on disk, I would download a new copy.
Glad to see your 6 cents went to good use
b00st33d
Central, CA
yes, the car was turned ON when the numbers were looping. I tried using the logger on my other car, got the key on the ON position, and it gave me values.
stevep
St. Charles, IL USA
If the values are jumping around it's usually damage caused by the caps leaking and the resulting corrosion.
I assume you mean the logger works but the values aren't stable.
