Hard block no water pump
bazeng
Melbourne, Australia
Both my cars are filled to the bottom of the freeze plug. no over heating issues whatsoever.
The only signs of over heating was during a knock out drag race where i had about 5 runs back to back with no cool down time. It started climbing towards the end.
So not ideal for track car imo.
JNR
ca
Quoting Olson:
You know how much a steel billet block would cost.... and weight?
Oh yeah, bet it's not cheap, but doing things correctly costs, although if you're resourceful not as bad as you may think. The weight wouldn't be *that* much more than a dense cast iron (for strength) block...
OK, maybe something like this doesn't exist, so now's a good opportunity to accomplish both: 1000 hp + cooling passages /ubbthreads/images/graemlins/smile.gif Surely it could be done.
I understand the alternative need though in this case, but just too bad you couldn't do something like that.
Terrance362
Winston-Salem, NC
Quoting EMX5636:
No, I'm talking about running the car on Methanol. No pump/race fuel, E85 etc. Injectors are about $2k IIRC. But the fuel is so cold that it doesn't require an IC and helps limit engine temps at all times.
There are tons of more info, but here's a short thread from EvoM.
Link
So I looked into some 2150s and Far as I know they can handle the meth. But I am looking into pumps right now.
onesickcrx
NY
I dont think 2150's are enough for meth and 900hp off top of my head
EMX5636
Bucks County, PA
onesickcrx is right. You could get by with 8 2150's though. Basically take a sick E85 fuel setup, and double it for methanol.
curtis
Clarksville TN
Go research the straight meth on the RX7 board's. I did an intake for a local guy that was building a rotary. He had the stock placements on the lower intake 4 new bungs on the upper and then addition hoses running from solenoids. Total alcohol was like 13,500cc a minute, yes 13 thousand. Rotaries just spit it out if they don't use it, but those guys know the ins and outs of the stuff
