rdomeck
Ok....So I purchased my car and it has always shifted notchy and stiff....I had the engine out to rebuild and didn't see anything out of line with the clutch. When re-installing I made some adjustments to the cables as they were off. Maybe a little better, but still not what it should be. So I purchased a used stage 2 trans from a local guy and installed it....Maybe a little different, but still not right.
I replaced the slave and master and it is bleed and adjusted correctly. Still not right. I have done the test to put it in 1st with the clutch in and the car moves. So clutch is dragging. I pulled the trans back out this afternoon expecting to find the step machined wrong on the flywheel....It measures .612-.618. It is a Centerforce pressure plate, I'm not sure about the disc and a stock flywheel.
I plan on replacing the bearing, fork and ball, but I'm kinda getting tired of pulling the trans. Anything else that I can look for?
