Got my valve cover back today
SmoothCustomer
Lexington, KY
Quoting 4thStroke:
Will you make a new thread when the valve cover is installed so we know what a fresh red powder coated valve cover looks like on a nile black VR4?
I don't believe anyone has put extra/larger holes in a DSM valve cover for proper crank case ventilation... ever.
While that may be true about a dsm valve cover, you might want to look at the one lap car, which leads me to the next point... why put them on the top instead of the side?
Quoting 4thStroke:
/ubbthreads/images/graemlins/bowroflr.gif
Quoting SmoothCustomer:
Quoting 4thStroke:
Can I see a pic of how the one lap vr4 has his fittings?
beaner
b'ham, mi
Quoting GSX_TC:
It's basically what you pictured, but on the side and looped together.
Did you tap the cover for nitrous or anything?
Quoting thedsmguy:
I'm in for pics of the gasket your using. Not sure which one to buy.
im just going to use an OEM valve cover gasket set, and the bolts im using are the ones that are currently on the car. nothing fancy, just reg bolts.
Quoting Beaner:
Quoting GSX_TC:
Lol wow you must not know much about cars. why the hell would anybody tap a dam valve cover for nitrous. just stop talkin champ lol
technically its a 1gb, its jake montgomery's old setup on Evil Eagle. but i think im just set mine up like the Onelap VR4. that way i know its a good setup. i got the whole build thread on his now.
beaner
b'ham, mi
Quoting GSX_TC:
Oh. It gets sucked in by the blow-by. Going through the valve cover it also mixes with the oily air, and since you can't compress oil, compression goes up a hair too. /ubbthreads/images/graemlins/idea.gif
You going to install it straight up or polish/wax it? The powdercoat will fade after all the heat cycles. Vasoline is good on powdercoat. Levels out when warmed up and makes the colors pop like 3d.
