Getting angry with car stalling
deez
Chico, CA
I just checked the battery, and with the car idling its 14.01V, with lights on 13.98V, and with lights and AC running 12.67V. Hows that?
deez
Chico, CA
Question in reference to setting timing....which plug do I ground to set the timing? Its it the one by the intake in front of the brake fluid reservoir with the yellow wire or the one above the clutch reservoir on the firewall?
Its the big oval connector, usually with a dust cover you have to remove, and one small pin inside you can clip to. You do NOT want the female spade terminal, which is the +12 volts to the fuelpump!
deez
Chico, CA
Okay, I checked the ISC setting and its at .50V, so thats good. Then I set the timing at 7 or 8 degrees, drove it for a bit, and it seems better. So do I need a different chip so I don't get knock now?
Yes, if a few extra degrees on the lower maps helps, I can try to design a chip like that for you.
deez
Chico, CA
Okay, so the car is running better with more timing, and so far no knock which is odd because it used to have knock. But it still has stalled 3 times since doing that work yesterday, which is much better. One thing I noticed when setting the timing was with the timing plug grounded, the idle was a little rough. Keep in mind the car has 264/272 HKS cams. It would idle smooth for a few seconds, stumble, idle smooth, stumble, etc. Now is that something I should use the BISS to smooth out, or is that just cause of the cams?
1990ggsxnj
Blackwood, NJ
This is gunna sound stupid...but are you SURE you have no boost leaks? Even something that seems tight can cause a leak at vacuum. Without a test, there's no way of knowing.
Normally more advance would probably create more knock in this situation, but double checking things never hurt. Hope you get this fixed, man.
GVR-4
Asheville, NC USA
I had the same problem and I deleted the FIAV and coolant lines and checked the throttle closed switch and the car idles much better now and hasn't stalled yet.
johnnyRacer
Tampa, FL.
Just did a log; I'm having similar issues. My idle is varying from 700-1100. My timing is irratic at -2deg to +5deg this is at idle. Finally, at idle I'm showing tps 12.1%. Tomorrow I physically check the tps, throttle plate, and timing.
deez
Chico, CA
So I am back to trying to solve this issue, and I replaced the ISC, reset the ECU, drove it for a couple days, and no help. Tomorrow I will reset the BISS. If that doesn't work, someone can buy a very clean white VR4 that is tastefully modded.
deez
Chico, CA
John, if you refer to the BISS screw, thats tomorrow. If not, fill me in
atc250r
Orange County, NY
The BISS is part of it but there's more to it than just turning the screw until you are happy with it. Go to www.vfaq.com and follow the directions there for setting base idle.
John
Quoting deez:
What base timing are you running now, as checked with a timing light? Have you tried more, several degrees more temporarily without getting into a lot of boost? I still think that more timing on the lower rpm's on the lower maps might be the answer.
deez
Chico, CA
If I remember right, I was able to get 7*or 8* out of the timing with no knock issues.
Try even more, to see if it helps with the stalling. I can make new timing maps that only have more on the lower maps if that helps the problem.
deez
Chico, CA
So I grounded things out and reset the BISS, and sure enough, it was off by about a turn and a half. Thats odd, because I have set that before. One thing that seemed odd was how easy the biss turned. My thought is that the o-ring is shot and not giving resistance to the screw turning. I will replace that soon. Anyhow, with that and pulling a bit of fuel out of idle, not one stall or attempt to stall on my drive. I hope this means its fixed /ubbthreads/images/graemlins/smile.gif
atc250r
Orange County, NY
If you want a quick, cheap, and easy way to "fix" the loose BISS just put a dap of silicone on top of it once you're sure you've got it dialed in.
John
