Galant GS-X
qwklil4
Member
Portland, OR
Realized I was actually pretty close to having it running, just need a hump hose on the IC and run a few vac lines. Apparently the NA intake manifolds only have one tiny port behind the throttle plate, and the TBs have none, so that's a little awkward.
qwklil4
Member
Portland, OR
Been running it around the last few days. Seems like the knock sensor is bad (it was leaking goo), gets a ton of knock on or off throttle at slight vacuum to positive boost. Looks like parts geek has the 1G sensor available, so waiting on that to really get on it.
