Galant eating ECU's
mitsu90
Illinois
It has been awhile. But I am still having this problem. I burnt ECU #4. It is the same as the others same green crud and same cap burnt. I will get pix of everything in the daytime..I only have one ECU left and it's my good eprom, I need to solve this problem once and for all.
spoulson
Worton, MD
It is worth having a skilled craftsman repair an ECU with leaky caps. Jeff O fixed mine back in 2004 with acid damage to a significant portion of an injector driver trace, and it's still running smooth to this day.
gvr4ever
central Indiana
Are any of the ECU wires spliced in to? Not sure what the green stuff is, but is sounds like some sort of chemical reaction. Why it would be on the plug is strange. Is this on the outside of the cover? While I guess it's possible that you fried all those ECUs, it doesn't seem likely that you could in such a short period of time, unless something besides leaky caps was a problem.
mitsu90
Illinois
Quoting gvr4ever:
When I lost the first ECU there was a SAFC in the car.
The green stuff is only on the middle plug, but it ends up on the middle socket on the ECU as well.
mitsu90
Illinois
Couple pix
Yeah, you have water and corrosion in the harness. You are going to have to eliminate that before you will have any success.
Peel off some of the insulation on the suspect wires some distance away from the plug so you can get some idea of how far the corrosion goes. Inside the wires you will never eliminate it from inside the insulation. You are going to have to splice in good wire.
mitsu90
Illinois
How hard would it be to just replace the harness? I don't trust my soldering skills to splice a whole new plug on there. /ubbthreads/images/graemlins/bawling.gif
mitsu90
Illinois
Quoting spooling92vr4:
that green sh*t is corrosion, are you just plugging the other ecus back in without cleaning that sh*t off first?
No I clean it the best I can and it keeps coming back.
