Fuel System Questions
jepherz
KC, Missouri
Hmm, I just did this last week and when asking the guys at NAPA if fuel injection hose could be submerged, they all said "yeah, no problem". I hate trusting those guys...
supersp0rt2
Plainfield, IL
Quoting joec:
More info on cutting the hard pipe and replacing it with fuel hose:
http://www.autoperformanceengineering.com/html/gvr4_3000gtnt.html
Also, from the above site:
"If you need to use a piece of fuel hose inside your tank, be sure it is SAE J30R10 spec hose. That hose is high pressure fuel hose that was designed to be immersed in fuel. DO NOT use fuel hose that is designed for inline use only [SAE J30R9]. It will not survive inside the tank."
Just bought the R10 submersible hose at Napa for $26 a foot, $30 after tax. Rediculous considering I only need about 3". So keep in mind that you'll need to pre-lube before buying this hose, it eases the raping they're gonna give you.
