Fuel pump question
FlyingEagle
THE Ottawa
Just a thought, but pulling the battery cables on any running car is bad because it causes a voltage spike. Modules/brain boxes do not like high voltage spikes. Battery voltage is going to vary with the temperature sensed and can be anywhere from 13.x to 15.x volts. Minimum battery standing voltage is 12.6V (6 plates multiplied by 2.1V per plate) at a full state of charge, but can read higher with a surface charge following charging.
But once I take the battery cable off the battery. It should run off the alternator right?
have you put a voltmeter on it to see if the alt is charging the batt while running and have you checked the alt fuse
SouthCaliVR4
North county San Diego
Quoting steverussell:
This is not a good method for testing an alt. the voltage spikes can damage other components as well as the alt.
Home method, with a volt meter, start the car & load the system. I.e. turn on everything, lights heater 4ways ect. you should still see at least 13+volts. try this again with the car after a spirited drive. if you see lower voltage something is amiss. with only the engine running & everything else off, you should see 14 volts or better but with no amp load it's not going to tell you much.
For sure do a voltage drop test on the grounds & primary alt lead to batt. fix any issues you find here first, then if you still show low output it's alternator time.
Thanks for all your guys help with this. But I'm dropping the car off at strictly modified and hopefully get all the problems this car has squared away.
AnotherNewb
Orlando, FL
Quoting Terry Posten:
#3 - Cut a slit in the floor of the trunk with tin snips and fold the floor up and out of the way, then you can pull the assembly out of the tank without disturbing the fittings (screws up the trunk floor pretty bad though).
Good luck.
/ubbthreads/images/graemlins/ooo.gif Little barbaric don't ya think?
toybreaker
iconoclast
... for the searchers who may find this thread ...
When the lines are ugly at the sending unit, many times they are still okay down at the front of the tank. They join the hard line just aft of the mustache brace under the car. It's a much more accesible location, and many times it's the only way to get things apart without twisting up the hard line that comes off the sending unit.
Soak the ever lovin dogshit out of them with the penetrant of your choice, and use flare/tubing wrenches. Many times, it helps to put them in a clocking that allows you to rest one against the body while still giving you room to squeeze them together. Just put pressure on them, and then give them a little "snap" with your other hand.
Wear gloves to protect your hands and eye protection to gaurd against any fuel spraying out if the system is still under pressure!
Now, you can cap the lines to keep crap from getting in there, and pull the sender with the short hoses still attached, letting you swap out the pump, and do what you have to do without hassling with the rusted fuel line fitting on top of the tank
It's important to note that if you go all McGilla the Gorilla on the connections at the top of the tank and the hard line on the sending unit get twisted up/distorted, you may end creating a restriction in that section of tubing that will kill the fuel volume that the pump can provide.
... and that can kill your motor at high rpm's when things lean out from lack of fuel ...
Just take your time, and even the worst corrosion can be dealt with.
I've seen a few vr-4's that were so corroded on the top that the studs were just stubs and the nuts were just an unrecognizable blob.
I removed the lines at the mustache brace, dropped the tank, and split the nuts off with a dremel tool by cutting them top to bottom with a cut-off tool. Then you just pry the nut open with a screwdriver, leaving the studs in suprisingly good condition, and ready to take a new nut.
As far as removing the battery terminal with the engine running ...
Flying Eagle and SouthCaliVr4 are spot on in their advice.
Removing the battery terminal with the engine running may have worked on your uncles 73 plymouth duster, but on these cars, there are many things that may be damaged by this "trick". From the ecu to the etacs module, abs computer (and on and on,) you may be making a simpe problem into an electrical nightmare
Not to mention you will probably pop the diodes in the alty when you reconnect it if it does stay running ... killing a perfectly operating alty ...
not recommended, to say the least!
Take your time and troubleshoot this problem logically.
A fuel pressure gauge will tell the tale if you're having a problem with pressure/volume/delivery.
Use it. /ubbthreads/images/graemlins/smile.gif
