FS: Second Owner VR4 1772/2000 Nile Black Mesa AZ $6500
I hope the tire kickers keep coming /ubbthreads/images/graemlins/grin.gif
Seriously though, Josh. I'd hate to see you sell this. I'm almost sure you'll regret it. Maybe just throw a cover on it and park it until you have more time/interest in it. I know you said space is at a premium for you right now, but maybe there's another solution?
G
zompton
/ubbthreads/images/graemlins/rofl.gif /ubbthreads/images/graemlins/rofl.gif @ the weed. Cheap bastards in AZ. /ubbthreads/images/graemlins/banghead.gif
donniekak
surprise az
There are usually 2 kinds of people looking at these cars. People looking for a 4 door dsm, they want cheap junk, or to lowball a clean car so they can destroy it. The second type appreciate these cars, and don't have a problem with a realistic asking price. Problem is the second type of buyer probably already has a vr4.
Jesus_Negros
USA
Haha this is some funny sh*t!
I wish I had room for this car. I'd buy it up. But, I don't even talk to sellers unless I know for sure I can show up with money and have the room to take it home.
In all honesty, KEEP IT! Cant regret keeping it.
IncorpoRatedX
Arizona
I know my asking price is fair. Which is probably why I'm on the verge of pulling it from the market. I took some pictures today though so I'll have some more info for this thread.
IncorpoRatedX
Arizona
ok so here's the photos i took of the car.
one thing to note; something i did not talk about in the ad:
The ABS computer is currently unhooked. The ABS system DOES work just fine, but when i bought new axles right before we moved, the passenger side showed up and was missing the ABS ring, i didnt realize this until I had installed the axle, attempted to back the car out of the garage and had that ABS system start going to work the second i hit the brakes. I pulled the car back in, jacked it back up and started checking the sensors thinking i had somehow harmed one, immediately found the reluctor ring to be missing. I kept the stock axle with the intention to remove the ring and put it on the new axle, but i was out of time before the move so i had to disable the ABS. The ABS will be working before someone buys this car, I just have to get a break between the other project cars im working on to do it. I just wanted to point that out before someone lost their sh*t over the ABS computer being unplugged.
Interior is filthy /ubbthreads/images/graemlins/frown.gif
Blemishes:
passenger side rear quarter panel ding, about the size of a quarter dollar
passenger side rear quarter clear coat
driverside rear door ding also about the size of a quarter
driverside front fender clear coat
IncorpoRatedX
Arizona
Also reminds me of a few other things i've done to this car;
did a new fuel filter at the time of the head rebuild
new master cylinder when i put all new rotors, pads and calipers on the car
slim line 12 inch fan wired to stock system installed at the time of the radiator
I'm confused. None of my ABS rings are on the axles. The fronts are inside the knuckles/hubs, and the rears are pressed onto the spindles. /ubbthreads/images/graemlins/dunno.gif
That is correct Mark. No ABS rings on the axles on this car. Must be something else.
IncorpoRatedX
Arizona
Ok, I knew I wasnt insane. I cut myself some slack because I own and maintain seven mitsubishi's and hardly any two are the same.
When I put new axles in, i backed out of the garage and the ABS started working it's butt off the second i tried to stop my roll. I pulled back into the garage and inspected the car, at the time I'm not sure why it didnt occur to me that the ABS ring is on the wheel hub but the drivers side had an ABS ring, passenger did not. Obviously these axles are used in a number of vehicles, according to Rock Auto:
EAGLE 2000 GTX (1991 - 1992)
EAGLE SUMMIT (1992 - 1996)
EAGLE TALON (1990 - 1998)
MITSUBISHI ECLIPSE (1990 - 1999)
MITSUBISHI EXPO (1992 - 1995)
MITSUBISHI EXPO LRV 1993
MITSUBISHI GALANT (1990 - 1992)
PLYMOUTH COLT (1993 - 1994)
PLYMOUTH COLT VISTA 1992
PLYMOUTH LASER (1992 - 1994)
All of these vehicles use the same driverside axle, so if any one of them calls for an ABS ring, I likely ended up with that model's axle.
That being said, it doesnt explain why the ABS was acting up. I'll be looking into that the first chance I get.
Pics for proof;
And just because I got such a kick out of this service record from the original owner;
IncorpoRatedX
Arizona
Did it cause any problems with your ABS Mark? I doubt it could have any impacts whatsoever but i thought I would ask because...
When i changed the axles i put the old axles into the new boxes and stuck them with the rest of the moving stuff, so i haven't laid eyes on them since i yanked them from the car. I just dug them out and double checked (for the sake of my sanity) and there's no rings on either of those axles, because they're likely original (no service record to indicate otherwise) so as far as I know the only variable in my axle change was either me inadvertently damaging a sensor, or that ring somehow creating an issue.
Quoting Alpha Male:
Nope. Although I was worried it might have clearance issues, that wasn't a problem either. And only one axle came with the ring, though I don't remember which side. I think driver's side.
There is probably only one side that has commonality with some later models using the newer sensing/rotor design.
I would look at the adjustment and cleanliness of the sensor. dirty/metal contaminated or out of adjustment sensors cause erratic behavior.
strokin4dr
Savannah, GA
I've damaged an abs sensor in the past by stressing the wire too much when installing an axle. You could easily have done the same here.
Good luck.
