FS: PC logger cables (SOLD)
Status
Not open for further replies.
jepherz
KC, Missouri
Logger cables for a PC. Serial connection. I will send hookup instructions and a CD with all the software you need to get logging. These will also work with many of the Palm platforms by simply using a null modem adapter. Tested and guaranteed.
$15 shipped plus any fees.
*plush carpeting not included.
What do you mean by a null modem adapter? Is this for the newer PDAs? I ask as your cable looks nearly identical to the one I apparently lost, and that one hooked right up to my Handspring's serial cable, AFAIK no adapter needed.
jepherz
KC, Missouri
All a null modem adapter is, is a serial gender changer, that swaps pins 2 and 3. Since PCs transmit on one pin, receive on the other, in order for the palm to communicate with them, you have to have the opposite for send and receive. If you had a cable for a palm, it was a male cable rather than these PC cables, which are female. Other than that the cables are identical.
Both cables sold, Thanks for the space.
Please PM me if you are interested in either a palm or PC logger cable!
-Jeff
Status
