FS: Cam Timing Tool
chrisfullwood
bartlesville, ok
I tried to slip this in, so i could hold the cam gears in place and loosen the timing belt, but i couldn't get it to fit, i can tell yet if its my intake cam is slightly off alignment, i tried rocking the crank back and forth a little to try to align it, but it wouldn't go. So i guess i have to pull the timing belt off first, and then do it.
hopefully it doesn't do that when i put my new cam gears on.
Doctor_D
Niles, Illinois
i did mine with timing belt off before putting tool in, At first seems to not fit like said, i just had to move both cams to fit in place, use your left hand for the 2 wrenches cam movement and use your right hand to fit the tool in. Simple as that.
Using this tool makes Timing very Quick and Easy. No Hassels here.
chrisfullwood
bartlesville, ok
thanks for the advice, i was figuring i should just pull the timing belt off, after i make sure its at TDC on the number 1 cylinder. Which i need to do to replace my cam gears anyway.
i'm looking forward to it making my life easy.
CKA
Wisconsin, United States
I am on what seems to be my last batch of these tools. I have 20 of them and probably won't be making any more after this. Even if you don't need one now get one now because 2 years down the road you will regret not having it.
I have been asked if I were able to make the Tensioner Tool. Here it is. Price for the tensioner tool is $15 shipped.
Bundle the Cam Timing Tool and Tensioner tool for a price of $40 shipped.
