FS: '91 Gvr4 Partout (560/2000) NB *Updated May 10th 2022
Hey Pot, hope all is well.
Do you have the long main center heat shield above the propeller shaft and exhaust?
Thanks.
kerry92gvr4
Vancouver, Wa
Do you by chance have a timing belt side mount, the power steering hose from rack up to the Reservoir and the Reservoir itself .
Wizardawd
Franklin, NC
Need cable release handle assembly for the truck and fuel door, center vent, a to b pillar trim drivers side, passenger dogleg.
Wiz
pot
Fayetteville, NC
I don’t have a full set but the handles I do have are in satisfactory condition with no plastic peeling off.
What side are you looking for and how many?
lowcashleblanc
Denver CO
Parts I’m looking for.
Headlight switches
Hazard switch
Transmission mount
Rear steering rack
OE Steering wheel
Nabeel
K.S.A
Pls let me know if you have the front/rear window tirms, roof tirms(the two long terms on both sides) also I am looking for Taillight backing plate, the rubber around the sunroof glass, Gauge cluster trim surround.
