FS: 735awhp race parts
Xcelerate
Active member
North jersey
Race parts for sale
These are what's left of my race car parts.  This whole setup got me to 735awhp and it is all in great condition.  These are from my 1990 1g DSM awd 5speed
Call or text (973)901-5525.  Do not pm me.  I don't check my pm.  Thanks
1-FP HTA86  turbo BB with twin scroll T4 1AR turbine and T3 .82AR 4bolt 2.5" turbine $1600
2-Custom 4" Turbotrix aluminum turbo back.  All vband from turbo to Exhaust.  This will mount on the 3" vband turbine housing on the turbo.  $ 400
4-drifts venom 17" wheels, with bf Goodrich drag tires about 500 miles $550
5-B&M modified oil cooler for 90 oil filter housing style.  This mounter on driverside like the Evos.  All in braided lines $100
6-Dual in tank walbro 255lph fuel pump.  Fuel pump hanger/assembly.  8an braided fuel Lines, ( 2)high flow filters.  Complete from the fuel pump hanger to the fuel rail.  Comes with 8an adapter for the stock fuel rail.  For 1g DSM.  This setup is a must for e85 setup.  Plus it's quite, compare to external fuel pump setup.  Direct bolts on.  Complete drop in.  Stealth mode.  $350
7-I will sell just the complete braided -8an lines and filters.  It's a direct bolts on from the fuel pump outlet to the fuel rail for 1g AWD $150
8-custom aluminum coolant reservoir, overflow tank for 1g. This tucked in behind the headlight and off the way foray sensor.  It helps with overheating problem.  And it's cool looking $100
Here's the pictures:
5OF2k
colorado springs, colorado
UGH! I want that FMIC setup and trans, but shipping would KILL me. GLWS sir.
-Jake
mitsuturbo
Near Seattle, Washington
I'm confused. Is it a dogbox, or synchro/helical transmission?
Straight cut gears, or helical?
Xcelerate
Active member
North jersey
It was rebuilt by dogbox racing lol. Stage 1 with dual synchro 2nd and welded diff. I believe their out of business now
Galantvr4559
Denver, CO
would you separate the fuel set up. i would need tank to rail fuel line, 1 filter, and adapter fitting for stock fuel rail. if so how much shipped to 80603 colorado??
turbojew
Dallas, Tx
Am I crazy or is there no trans listed?!
