FS: 1992 Galant vr4 5000/ Denver
the car has a decent amount of mods, just pm me if you have any questions
-Hks air filter with 2g maf adapter
-2g maf and Dejon intake pipes
-fp ported evo 3 big 16g turbo, evo 3 ported exhaust manifold, ported O2 housing
-Hallman manual boost controller, 52mm boost gauge
-custom 3 inch exhaust, downpipe, and vibrant muffler
-JDM galant vr4 front mount intercooler
-Aeromotive fuel pressure regulator, aith carbon fiber fuel pressure gauge and stainless steel lines
-Denso 560 cc fuel injectors
-ECU caps replaced
-3 step rev limiter, 8k rpm redline, no fuel cut, octane valve reset, no lift shift feature
-hardwired Apex'i SAFC digital fuel controller
-New bosch o2 sensor, oem knock sensor, oem fuel filter
-Summit racing trunk mounted battery kit
-JDM mountain front brake rotors, brembo rear rotors, Axxis metal master pads
-Low milage GSX trans ACT 2100 series clutch, new slave cylinder, ss clutch line
-New radiator with Spal 13" slim fan new hoses, and 180 degree thermostat
-short shifter with leather boot and carbon fiber knob
- 1g eclipse steering wheel, 1989 galant under dash panel with pockets
-Synthetic fliuds everywhere ( mobil 1 oil, redline gear oil)
-EGR blockoff plates
-Kenwood head unit, sidewinder alarm, Ipod connection
-Rebuilt head, with MLS headgasket, 3g lifters and 3 angle valve job
-brand new ngk wires, and BPR7ES spark plugs
-Solid underhood shifter bushings
-New kevlar timing belt and balance shaft belts
-New idler pulley and tensioners
-Sparco seats with sliders and custom made brackets
-HKS blow off valve recirculated
-Nrg oil catch can
-New valve cover gaskets
-ARP head studs, so the boost can get turned up, currently at 18psi
-Walboro 255 fuel pump
-Brand new all season tires
Serious Buyers only can contact me by cell, my number is (303) 619-8017
forgot to add that I am asking 5000 obo and the vehicle is located in Denver, CO
toybreaker
iconoclast
Please edit your post title to include your price and location or your ad may be removed.
Thanks, and good luck with your sale. /ubbthreads/images/graemlins/smile.gif
