The rear JDM bumper sits no lower than the USDM version. It's an optical illusion due to the built in lip it has. At the bottom of the wheel arch they are the same anyway.
Thank you sir! It's still a long going project, because I'll need to install those BC Coilovers so I can raise her up a bit for those much thicker and wider tires, then I can put the EVO X Brembos on without a problem, and if needed I'll roll the fenders a bit as well.
