BoostedAWD91
yes true, i should of stated that differently, i didnt mean u should go get a 10mm bolt at the hardware store to use cause. I meant that they arent made extra strong. Sorry for the confusion.
since its possible the right washers and stuff arent on there, how many washer and lock washers are supposed to be on each bolt. The one bolt that was holding the bracket on when i found the broken bolt, turned out to be bent. I wanna make sure its spaced properly this time
