evo 9 or oem 2g pistons
5OF2k
colorado springs, colorado
Quoting yeti:
Quoting yeti:
Quoting iceman69510:
"1g rods 2g pistons don't clear 1g oil squirters"
I have done these before and while it was close, there was no interference if installed properly.
what is there to do right?
i was told they do not clear, and you have to shim the skirt..
again I could be wrong
I didn't say anything that wasn't correct.
I wanted to point out there is a concern with the squirters that nobody mentioned, iceman said you had to do it right, I was just asking how you do it right.
To my knowledge the squirters is a concern, if they are not I would like to know how..
I beleive he was talking about the "shim the skirt" line....that'd be incorrect. you dont shim skirts. its impossible, regardless of the setup.
dsmless
tucson,az
going threw my notes yesturday, saw a sheet were I wrote the clearances from squirter to piston skirt, it ranges from 1/8 to almost 1/4 inch, (used my 64th inch scale) so really just guesstimated, being said tho you have plenty of room to run evo8/1g rods, I went with evo 8 pistons because they were free from a buddy (45xxx miles) and I had a local machine shop resize the rods which came up to 200 bucks, so far so good, If I could do it over I would def go get some evo 9 pistons off the evo forumns
3rdstrikedsm
32159, FL
The best stockish set up would be a late 2g 7 bolt split thrust block with evo 9 pistons AND rods as this has held 600+ whp a few times over in the past and there are many many benefits to running a 7 bolt contrary to popular uneducated belief /ubbthreads/images/graemlins/wink.gif
Launch
Texas
Ill take " What is 1g 7 bolt (93-94) oil squirters, for RTFM, Alex
:p!
Question; How do those valves work with backwards facing evo pistonz? " One of these is not like the other "
just wondering /ubbthreads/images/graemlins/smile.gif
You aren't serious are you?
Your eyes will help you with that question.
