ECMlink plus Cyclone
My guess is that it is because of your 8.5:1 compression. The 2G maps are much more retarded than only 3 degrees from the 1G maps in the mid-rpm's during spoolup. Are you running DSMLink v2 or v3?
Hertz
Chicago, IL
How does the JDM ECU (or Keydiver mod) operate the butterflies? Solenoid to vac canister? When is it applying vacuum? Low revs?
Vacuum is applied to the Cyclone diaphragm to keep the secondaries CLOSED. That part doesn't change. The only thing different between the way I activate it and the JDM ECU activates it is the solenoid operation is reversed. I energize the solenoid at 4100 rpm, which causes the FPR solenoid to dump the vacuum in the diaphragm out to atmosphere, opening the secondaries. The JDM ECU energizes the solenoid UNTIL ~4500 rpm, but has the same result.
Quoting keydiver:
Running V3 with 2G maps thats why I only used 3 degrees, I didn't want EGT's to soar. Also running a 3" GM maf that is maf comped in V3. Changed plugs several times, NGK BPR7ES gapped at .029" and am using a wideband with street tuned fuel ratio holding 11.0 across the rpm range.
Every time the butterflies open, shows knock pulls timing and then it smooths out. If I leave the butterflies open all the time there's no issue.
belize1334
Bozeman, MT
I noticed that mine used to get two counts of knock right when the butterflies opened. I never disconnected them to be sure but it was consistent with the rpm range and it was the only knock I saw. I decided that it was either the sensor misinterpreting the sound of the butterfly valves slapping or it had something to do with a momentary disturbance in the airflow reading do to the sudden availability of the extra runners. Either way, it was only 2 counts and didn't affect timing so I was never concerned. This was on my OEM long-block with a keydiver 92 octane timing curve.
atc250r
Orange County, NY
Quoting prove_it:
Quoting keydiver:
I might be missing something here but more advance = less EGT.
John
I worded it wrong, earlier I mentioned that I had link set up to use the FPS for the butterflies and I set it up to pull 3 degrees when they opened. I just worded it wrong.
