dyno tuning with 1051
Brianawd
Portland OR,
That's awesome timing on 9:1. It really shows that E85 can make amazing power when tuned for it. Knowing how much power Brian made on this turbo, I had higher expectations. Seeing others' numbers makes me feel better about mine. It's too bad E85 stations aren't more plentiful in my area.
Mark you set up is making great power. I know if you ever wanted to toss in some e85 and bigger injectors you can make 500whp easy. Now how long your bottom in will hold up /ubbthreads/images/graemlins/devil.gif. Enjoy the car the way its sits. You are at the perfect hp for a street car. 99% of the time I keept my car at 430 hp level for the street. 562hp was just to much for a street. 400-450 is perfect. Fast but still safe for a street car.
DynastyLCD
Harwinton, CT
Quoting turbofonz:
How much timing up top?
Interesting, I've been up to 33lb's on a 30r on straight pumpgas so far.
my stock bottom end took over 30 psi and around 19-20 degrees of timing from the 3052 on pump 93.
you are just gettin started fonzy /ubbthreads/images/graemlins/wink.gif ive logged right around 50-51 lbs/mn at 30 psi. start working your magic!
turbofonz
Granby, MA
Stock block, HTA 30r, 33lbs peak so far, only 11* up top. 93 octane. Still tuning a LOT, but it's definitely strong. Airflows over 50lb/min.
Baby steps, getting used to pumpgas after running corn for the last 2 years. Car definitely feels over the 125mph mark and Link's logs are saying also.
Not making a comparison or anything Mark, I know NEDSM has a few 30r+ cars running well into the 30's of boost on straight pumpgas. Your timing is definitely up there. Lucas knows his sh*t.
turbofonz
Granby, MA
DSM76. 33lbs @ ~4250. Trying to get it lower. Still pig rich coming into boost and everywhere really. Never really dialed in these 2150's.
Brian, I'm definitely happy with this power level on the street. I'm just surprised at the power differences between all the different 3052 setups. Your's is extreme, lol.
Guys, my logs are showing ~57lbs/min near redline. Does that sound accurate?
turbofonz
Granby, MA
Mine's right around there too, but up top like that SD calibration has a big affect. Hard to compare airflow numbers when a car with a improperly dialed SD table can be reading wayyy off. There's a lot that the log can tell.
How is drivabilty with v3 compared to translator pro? One of my favortie things about link vs. other crap is the little stuff. Knock light I can't live without, then just other little things make the car that much better.
Brianawd
Portland OR,
What rpm are you seeing the 57lbs/min. You should look at look between 5k+5.5krpm range. At 5250 I was at 54lbs/min. Turbo is rated at 52lbs/min so I was maxed out.
At 5250 I'm only seeing about 43lbs/min. That makes more sense.
I love driveability of V3 over Maftpro so far. So many cool little features to play with, and I don't have to chase problems between a burned chip or Maftpro settings if there's an issue. I really hate piggy-back systems now. I think I may even do V3 on 503.
4thStroke
Vancouver, WA
57lbs/min is too high, the SD table is off a bit. There won't be any adverse affects by this, just misleading airflow numbers. The thing that sucks, is that if your gm/rev is off at idle and you then get that set where its supposed to be, then mostly all the SD table values will then be off as well. I'm guessing the global is set lower than it should be while the SD table is where your fuel is coming from.
At 440whp, I'm flowing ~48lb/min at 26psi.
Before I spent a bunch of time setting up the SD table and getting the gm/rev set right at idle, I had some really high airflow numbers as well.
What are you seeing for gm/rev at idle?
I think it's in the mid 30's. I had it set at 26gm/rev at idle, but that all changed after Lucas took over, haha.
WaRrIoRs16
West Richland, WA
Quoting Brianawd:
Doesn't the 5k to 5.5k RPM range only apply to the BoostEst? Speed density is what is telling the ECU how much air is there, so shouldn't the airflow be correct or as close to correct as possible at all RPM ranges? These are the impressions I was under.
WaRrIoRs16
West Richland, WA
Also, heres a thread to help dial in your WOT SD table. It is based on matching your wideband readings with your AFRest. You must have your fuel settings dialed in correctly and be logging your wideband through link to use it though.
SD WOT Tuning
