Doing carrier bearing install right now...have questions
CP
West Simsbury, CT
That's as far as I got. Toybreaker has been helping with suggestions, but I didn't have time yesterday to continue. The lobro is pretty solidly attached to the thin aluminum cap with the rubber boot in it. Is that what you're talking about?
Remember that my lobro AND that cap with the boot are both getting replaced with new parts. The only part that gets re-used is the portion that's bolted to the other section of driveshaft (the rear-most section) and can be seen in the photos all shiny and clean.
Armitage
Herndon, VA
Right, but what I think is happening here is you're pushing and pulling the assembly at the same time with the gear puller. What I recommend trying is clamping the lobro in a vice and then using a punch or chisel and a hammer and tapping lightly around the circumference of the flange. With all the bolts removed, those pieces are just pressed together and should come apart pretty easily. Once you remove the lobro from the flange, you should be able to remove the flange from the drive shaft.
14u2nV
Agency/St. Joe, MO
I don't know how much trouble you ended up having on the lobro joint, but the way I got it was to hang the tube off the side of the bench and use a mini sledge with a bar that fit down through the splines. Came off with about 3 hits.
I did mine about 5 years ago and I don't remember how I did it exactly but I think I took mine apart the same way. I know I only had trouble when reassembling the joint. The balls all twist in which made it tricky.
