Quoting Hertz:
BTW, SAFC should be set to 2 cylinder for wasted spark system like ours.
Only if you follow the incorrect wiring information found in Apexi's manuals. If you connect the green RPM wire correctly to Ignition Pulse Detect pin 109 or the CAS pin 21 you can set it to 4 cylinder.
