Cyclone Manifold Gasket Questions + pic request
GVR4_1057
Brucetown VA
Right on! I will do that tomorrow. I will photograph with a sale in the pic and I will dimension some distances so it can be scaled.
belize1334
Bozeman, MT
Remember that there are two gaskets of interest which are unique to the cyclone manifold. Hopefully you have both?
Dialcaliper
Bay Area, CA
Rubber and paper/coated gaskets seal better than copper or metal/composite gaskets - the only reason to use the latter two is for high temperatures where the first two would degrade. A paper gasket with high tack spray will work for most things.
Quoting JNR:
Good ideas...
Curious if thin copper would be a better choice?
As for tracing the outline, I'll probably measure it all out for the holes using my trusty venier calipers and not too worried about the perimeter, except that it goes beyond and looks halfway decent. I was going to suggest you can take a thin piece of gasket material (for instance), hold it down steady, and press around the larger holes and/or use the old pencil and tracing paper technique, with 'sketching' on an angle so the holes will come thru. You know, like they do on forensics to see the nasty note you left before.
