I wanted to point out a few things since I think this post sort of testifies to the way DSM modding has been done for the last 20 years. To my knowledge, this use of the dual ignitor to increase spark potential in the COP setup has not been done before. This is a fairly amazing piece of information considering the sheer volume of DSM sites and tuners out there. Some of the guys over at EvoM are pretty sharp cookies and we didn't conceive of anything like this in that entire post. Credit needs to go out to Belize1334 here provided that the future testing does back up what appears to be a better system. This same ignition system has been in use for decades now and while the bits and parts have changed, the main system has remained the same. Not a lot of data has been gathered on the actual workings of the system as it has mostly been discussion about functionality, i.e., will system "X" work on Car "Y". Another site will eventually pick up on this and claim it as their own I am sure. GVR4.org is small potatoes in the overall 4G63 community and tends to be focused a lot on restoration due to the age of our cars. It is nice to see a serious, albeit small, tech effort come out of the community and I'm glad to be a part of it.
Now onto updated results.
It is late as George Burns but I got a few hours sleep earlier and have found myself not tired in the least. It is also, unfortunately, 2:00 a.m. here, which means drunks and cops. Regardless of the risks, I set out on the highway to push this testing phase to another level. I have a small issue which is that my boost gauge reads in k/pa, roughly bar, and only goes up to 1.5. I have another few gauges I will install in the near future to get an accurate reading and will probably install the 3 bar map sensor so I can read boost directly from my EvoScan logs. Ignoring this issue, I turned up the boost again.
At what reads out at about 1.9 bar I let off the gas as it is 2:00 a.m. and I don't have anyone to call should something go a foul. The turbo was not at full boost at this point and I expect it would have went well over 2 bar. The real increase in butt dyno power was again noticeable. Power delivery was outstanding. My car has a bit of a rake to the stance which is a good thing because the front lifts up past horizontal during acceleration. Had I dropped the rear more, I may have lost sight of the road. There was no spark break up at an estimated 27-29 PSI high RPM in third gear. I was limiting boost by throttle so was only about 1/2 to 3/4 throttle during the runs. I also did several quick launches in 2nd gear almost to redline, again, throttle limited for boost reasons, again not a single hiccup or stutter.
Now compare.
The car 2 days ago had spark stutter at 17 PSI, gap set at .022. Tonight, 28(ish) PSI, same gap, perfect.
I have changed only one thing between then and now. I may actually pull the plugs and increase the gap to see if I can find a breaking point.
P1 - Adding an additional ignitor in parallel to the factory ignitor should increase available spark at the plug due to electrical magic.
P2 - Brox added an extra ignitor in parallel to his car and his ignition problems have disappeared.
C - Adding an additional ignitor in parallel to the factory ignitor benefited Brox's car.
That is as much of an argument as I can lay out right now. If we can add a few more premises for the argument we can solidify the conclusion. For people who are interested, I have ignitors I can get on the very very cheap. If you consider this modification to the ignition, in order to add valid premise to our argument, I will gladly help make that a reality. I am not looking to make any money off this. I just want others to validate the argument.
I dare not post a schematic of this because it is so simple a solution as to be easier said in words.
If you have two identical ignitors as I did, you simply cut back the wrap on the factory harness going to the ignitor about 7 inches or so. You will be cutting and soldering the three outside wires from each side. The white wire is the tach wire and does not need to be cut. Cut the wire, strip both exposed ends, strip the corresponding wire on the harness of the new ignitor, and slide some heatshrink down the factory harness side wire, Tie the new ignitor connector wire to the side opposite the one you slid the heatshrink on, tie the combined wires with the other, solder, heatshrink, done. Repeat for all six wires. Take the white tach wire from the new connector, fold it over and heatshrink it. Done.
As far as mounting, again, I used the bolt holes for the factory intake manifold brace. I drilled out the hole on the ignitor backplate to fit the 10mm bolt(14mm head), and bolted them in facing up and center.
If anyone would like to add data to this set, shoot me a PM. I can run down and grab several ignitors and harnesses and will probably do so anyway.
/brox
