Code 44
The intermittent nature of your problem still points to either a bad connection or possible ECU damage. Usually if a transistor or coilpack go bad, they go bad. Look for any signs of oxidation on the plugs and connectors where the transistor and coilpack plug in.
I had the same issue with my 90. The plug for the transistor pack was bad. corroded like crazy. One of the wires was broken off and made a very faint connection. I soldered in a new plug.
Pull back the boot and check for split wires and corrosion.
