Clutch cable
Gilga5
Active member
Worcester,Ma
So I ended up replacing both clutch master and slave and now it functions properly. Also, from the car sitting in the garage for so long might of caused it not function and fluids drying up within the lines ect...either way everything is all good and I appreciate all the advice given here. Thank you!
CutlassJim
Manchester, NH
Quoting gvr4ever:
It was always my understanding that old hydrophilic fluid can absorb water, contaminants, etc. It's why it gets dirty and looks like crap. While they fluid itself might not compress, everything else in the fluid does.
I thought a full flush and replacement was just maintenance.
Maybe you are thinking of brake fluid? The moisture won't compress but with the extreme temp brakes see it boils in the likes and releases oxygen and then that compresses.
FlyingEagle
THE Ottawa
Quoting Gilga5:
Your seals either wore out from repeated use or the combination of scoring in the bore eventually worn them in spots that allowed fluid to bypass the first seal or both in the system. Check the interior of your car where the master comes in to make sure no fluid is sitting on your firewall/floor board area eating away at the painted surfaces.
Figured it was all just a weak and aging pressure system. Glad you got it back up and operating correctly.
