CAS confusion.
gvr4ever
central Indiana
Quoting AllanL:
Quoting boosted_85:
when setting ignition timing are you grounding the correct pin and using a test light to make sure that you can adjust timing by rotating the cas. Seems odd to me that you can rotate the cas with timing pin grounded and ignition timing doesn't change.
when grounding the ignition timing adjustment connector, the check engine light should light up...
does it do this?
No, my CEL doesn't come on when grounding the plug to set the timing. Are you sure its suppose too?
