Car caught on fire. Oil fire and HUGE slick
Quoting Brianawd:
How do you know you don't have excessively high oil pressure /ubbthreads/images/graemlins/dunno.gif? You don't have a oil pressure gauge to tell you.
My oil pressure should be similar to stock. I never removed the front balance shaft, so the oil isn't completely blocked off there. That and an oil pump with 136k miles on it should mean pressure that isn't excessive, IMO.
Brianawd
Portland OR,
Lots of people leave the front shaft in and and still end up having high oil pressure. Just a fyi
Well I am just going to have to buy lines and throw on my 90 OFH. I will port that beforehand. I'm still curious as to the difference between before and after the oil filter seal blew and why my pressure is doubled now. I considered the possiblity of the sender being rattled and now reading incorrectly, but the seal did indeed blow, so the high pressure is there.
Quoting Brianawd:
Meh, it's been like this since '04. I'm sure if I had any excess pressure issues, they would have popped up by now.
Maybe one day I'll install an oil pressure gauge in that car. I just don't feel like dropping the money on a matching Defi gauge and dealing with finding a place to put it.
I guess it's possible, but I don't really see how people could all of a sudden have a high oil pressure issue if they leave the front shaft in. By leaving it in it leaves an open path around the bearing for oil to flow, rather than completely blocking it off by rotating the bearing. The only difference is it's not spinning. /ubbthreads/images/graemlins/dunno.gif
I would think that by the shaft not spinning, it wouldn't scrub off the excess oil flow as much. Im sure you might have oil pressure thats a little higher than normal but probably not as high as everyone else with complete BS removal.
mitsuturbo
Near Seattle, Washington
I'd try pulling the relief valve out and just make sure it's not stuck before pulling the timing cover and whatnot. Who knows.. it could be coincidental that the plunger somehow got stuck when your problem occurred. That may be what CAUSED your problem. Excess OP because relief stuck, blew a gasket. At least you can get to the valve without pulling the cover and may be able to pull it, check it, clean it, and put it back together.
I had to pull the OFH to get to the relief valve. It's been five years, but I'm pretty sure I tried to get to it without pulling everything, and it didn't work.
There's one bolt behind the cover you cant get to w/o taking it off. You can however pull the big bolt for the relief piston. I for one dont find it difficult to pull the timing cover.
I replaced the entire OFH because I didn't want a questionable relief valve plunger in there.
I assume you checked the one that you put on there? /ubbthreads/images/graemlins/smile.gif
mitsuturbo
Quoting turbowop:
The actual valve has a 21mm plug at the bottom of it, i believe. After removing it you can take out the spring and then the plunger. It's not relevant now since he's replaced the entire housing, i suppose.
