CAPS Requests
atc250r
Orange County, NY
You're probably going to need the JDM CAPS since the 7 was never a USDM car. I don't have that on my PC. Hell, my CAPS CD doesn't even have the Evo8 on it /ubbthreads/images/graemlins/bawling.gif.
John
JB
MA
Mine has ct9a, but it only lists the 03-05's fed cars(rs, mr, and gsr)
good luck finding JDM caps, i know you can get books from mitsu that have all the JDM Evo part #'s.........the 3 book set is like $900.....if you need part #'s from something newer i work at a dealer so i always have newest version of caps
Nuts / bolts / washers for 4-bolt axle cups. I have a 4-bolt rear, with
brand-new cups, but no bolts/nuts to connect it to the wheel.
Need part #'s for these. Also, are they the same as the 3-bolt hardware ?
Or do I need to buy 8 sets ?
atc250r
Orange County, NY
The bolts from the 3 bolt set up work fine, I then used a generic bolt that we had in the shop hardware bins. The bolt is a 10mmx29mm so a 10x30 will work. Here are the part numbers in case you are not willing to go the route I did:
MB160664 - Bolt
MS450043 - Washer
MF430122 - Nut
The little blue cylinder-like one that's right above the plate that the fuel pump is attatched to, the plate that bolts down in the hole in the trunk. It's got hoses attatched on each side, one hose on the front side, other on the rear. If that description sucks, let me know, I can get a picture of it.
can someone check a temp sensor #, my Napa part # crosses into a MD069879, but sometimes my interchange isn't great, so if someone could check that'd be great.
Thanks,
Mark
Okay, it's not for a Galant, but I just can't seem to find the part number.
Need an axle shaft seal for a 1995 Mirage 1.5L automatic. Driver's side.
I guess I should find myself a copy of CAPS. Probably wearing out my welcome with part # requests.
quasimondo
Nairobi, Kenya
What's the part number and price for #5?
