Cap Throttle Body Lines?
Terry Posten
Davenport, Iowa USA
This is what I did.
But I did "tee" the fuel preesure regulator and install the boost gauge at that point to free up the TB ports all together.
I then took 4 vac caps and filled them with JDWeld and capped them off. Let sit overnight to cure and you will never have a leak again at those ports.
Yes, but I would suggest finding ones made from vinyl, rather than rubber. Rubber ones tend to crack from engine bay heat over time and can create vac/boost leaks.
Terry Posten
Davenport, Iowa USA
Wops right. If you get the wrong ones, they will crack in a few months.
The problem I had was I kept blowing them off. /ubbthreads/images/graemlins/grin.gif
