skivittlerjimb
My GC's did that until I installed the camber plates.  The free length of my front springs is a tad bit shorter than I would like.  I'll have to look up the exact length that I have.  They never did it while driving, only when turning the wheel with the car stationary or just creeping along.  Tender/helper springs would be ideal, but then so would spending an extra $1k on a full Hot Bits set up!
When I installed the camber plates, I'm guessing that between the Hot Bits-supplied metal bushing, the stock washer, the stock upper spring perch (which I reinstalled just to keep splashes and such away from the bottom of the camber plates), I took up the bit of the slack between the Ground Control upper spring hat/perch and the spring that had been allowing the clunking/binding to occur when the car was at rest.
As for the condition of your strut bearing, it's hard to tell, but they should rotate pretty freely. If you take the strut completely out of it, can you spin the camber plate easily around the bearing with no binding/scraping, etc.?
If the camber plates bearings are good, you may want to consider a longer free length spring. The nice thing about GC is that pretty much any combo. of spring rate, free length, and spring overall diameter is available relatively cheaply. Also, you could raise your ride height up a bit and see if you still have the clunking and binding problem. Good luck!
-Jim B.
1432/2000
167k
-Jim B.
1432/2000
167k
