Buying vr4 next week
91Vr4white
Active member
Owensboro, KY
Lol mine is white so I guess I'm good. It is number 1058 I believe. Ok so I'm just going to go with some standard replacement struts I guess. Right now I don't want to so any modifying unless I can just bolt it in. I have a history if getting carried away and I have to contain myself with this car at least for now. My "race car" is still my mustang an while it will be up and running soon I still have a lot of work to do on it.
Ok so I want to level the car out. What is the cheapest reliable way to do this? The car will remain stock for now I noticed the car burns oil when in boost so the turbo seals are going I'm guessing. I will probably do a boost controller and exhaust and then leave it alone until funds allow a rebuild then a 16g turbo front mount ect.
I need to do something about this shifter! Is the Evo shifter direct bolt in? Is there a bushing kit or something I can buy?
There are shifter parts availible. 1g eclipse stock shifters are shorter and feel better. Also the bushings can be replaced.
Your key websites to buy stuff are as follows:
Jnztuning
maperformance.com
extremepsi.com
slowboyracing.com
Pretty much everything on the GVR4 is the same as a 92 Eclipse GSX turbo. Most parts will crossover. Body parts, no. Exhaust will but is too short.
