tektic
Looks a little different. Oil pan installed with new bolts and "the right stuff" gasket maker. Half inch npt threaded oil return flange installed on that. Head torqued down with evo 3 mls head gasket Arp studs. Ported 2g ceramic coated manifold with new oem studs and nuts. Evo3 7cm hot side with arp bolts ported and 2g 02 housing ported.
Ceramic coated my water pipe
On the other side cyclone manifold cleans up and installed with fabbed coil bracket. Tb is on the harness is attached and connected. I swaped out the lifters for a new set. The other set were in a failed motor. Would have just cleaned them but now I have 2 sets of revised lifters.
On the sides the rear main seal is installed with new hardware. The gates racing timing belt is installed with new pulleys. Timing cover ac bracket water pump ps pump and engine mount, all installed.Waiting on a bracket for my turbo tb. A cover for my small 16g and then it will be time to install the flywheel.
