Quoting manikbastrd:
The build is for a replacement bottom end for my car. I have a local machine shop who will do all the machine work, and do ring gaps. He is actually a buddy of mine so he will probably oversee me assembling the block itself (not my first but I am not super confident). Build is for a bottom end that will handle up to 700HP. I am only really shooting for 500-600 AWHP (gotta be able to beat my buddies evoX with 540AWHP), but want to have it good to go, and not have to worry about anything (I have not decided on a turbo yet, but I do have a head built). I thought about going stroker or destroker but can't come up with a great reason to do either. List is as follows, please chime in if you see something bad or that I should reconsider...
Stuff I need still
edited)
Good core for bottom end w/Crank
Mahle Powerpak 9.0:1
Carillo Rods
ARP Main studs
Clevite 77 main and rod bearings
New Mitsu oil pump case and gears
New mitsu water pump
Balance shaft delete kit
Fluidampr harmonic balancer
Haven't decided on HG yet...Thinking Mitsu MLS or Cometic
Things I have:
ARP Head studs
New Mitsu timing components
Stock Timing belt
7bolt head bored for 6 bolt studs
-1mm overbored valves
-ported all the way around
-HKS 272/272
-New Topline revised lifters
-Manley Springs and retainers
JMF intake manifold
Stock 1g TB
FP exhaust manifold
Turbo and o2 housing TBD
Thanks in advance! /ubbthreads/images/graemlins/worthy.gif
-Manik
You will need some arp bolts to go w that fluidampr balancer since it is thicker than the oem balancer. The stock bolts arent long enough and dont get enough threads in there. A few guys on tuners experienced the bolts shearing off.
If I remember I will post the size and arp part #.
