cheekychimp
MDK87,
Regarding the front hubs, be aware that again the hubs seem to widen the track. I had a front plate diff and I don't know if that makes a difference to using a transmission with the stock diff but we had to use an RVR axle on the passenger side (RHD JDM car) which worked perfectly. We 'think' that an RVR axle on the driver's side might therefore work. Sadly we didn't have one to try. The difference in length of the stock axle caused me a lot of problems and I went through two wheel bearings on the driver's side in as many months until we managed to get a spacer machined to the correct tolerance to solve the issue. Again I reiterate it is possible an RVR driver's side axle might solve this problem. If you do this and confirm it works, I'd highly appreciate it if you could source me another RVR driver's side axle to swap in rather than using the spacer which whilst it works is still a band aid in my opinion.
Also, like I said, I am also not sure if a stock diff would make fitment any different/easier.
Paul.
Paul.
