Brake Master Cylinder where to buy?
jackal
Active member
CO
I am looking for a new Brake Master Cylinder but I can't seem to find one locally. I ordered a new one from rockauto but it started leaking shortly after installing it. I tried Napa but they would have to special order it.
Any ideas on where to find one locally in Denver?
Muskrat
Lexington, KY
If you need it quick, a mitsu dealer might have it in stock or within a day or 2. Otherwise go to JNZ Tuning's website. They offer OEM parts at a significant discount. Since you've already had bad luck with the rock auto sourced re-man'd unit (just curious, who manufactured it?) OEM is probably your best bet.
Terry Posten
Davenport, Iowa USA
Buy it from your local parts store that has a lifetime warranty. A new EOM one from JNZtuning is $290 (w/o shipping). At Autozone, you will pay $50 (after core return).
So buy locally and save yourself $250. If it fails again, they will replace it.
jackal
Active member
CO
The leaky one I got from Rock Auto was a Raybestos.
Thanks for the tips. I ended up ordering one from Autozone as you suggested. It was like $50 if you bring them the core like you said. Should be here on Tues. Hopefully this one doesn't leak. Kinda tired of bleeding brake lines for nothing.
Muskrat
Lexington, KY
I actually took that advice as well. Should be here tuesday. Forget $250 for $50 I'll swap it out a few times if I have too!
Guess we can compare results, lol.
I did the same when I upgraded my brakes & went to the local Advance Auto store. Haven't had a problem since.
