Blew my motor becase of oil filter failure
uncleben4rice
antioch ca,
Quoting theevozero:
This thread is full of stupid.
Your Stupid. Oh you just don't have any power in your car so this dont apply to you.
Gizmovr4
andover,NJ
/ubbthreads/images/graemlins/rofl.gif /ubbthreads/images/graemlins/rofl.gif /ubbthreads/images/graemlins/rofl.gif this was fun to read !
Olson
Moreno Valley CA
Whats up dude... miss you and conrad. i see you havent changed one bit /ubbthreads/images/graemlins/laugh.gif keep it real dude
mitsuturbo
Near Seattle, Washington
This whole thread is so full of fail i don't even know where to begin. Wow..
Just...
WOW. /ubbthreads/images/graemlins/uhh.gif /ubbthreads/images/graemlins/uhh.gif /ubbthreads/images/graemlins/uhh.gif /ubbthreads/images/graemlins/uhh.gif /ubbthreads/images/graemlins/uhh.gif
uncleben4rice
antioch ca,
Olson; Whats up Dude? I got the car back up and running. Eagle rod motor with 8 to 1 JE pistons. Magnus sheet metal intake this time. Next mod will be the 2100cc E85 spitters. Im running 1650cc now.. And I have a brace on the oil Filter /ubbthreads/images/graemlins/banghead.gif Im so noob at this. I wonder what they will say next?
Listen up Kids, the Uncle just wanted to bring light to the subject. Watch your oil filters they can\will come off if your not careful.
Bigger crank case vent system is also in the works. I run the RRE setup currently.
Twop; is it true that the oil actually bypasses the filter at certain pressure?
Kids you can learn a lot from a dummy. /ubbthreads/images/graemlins/crazy.gif
Uncle out /ubbthreads/images/graemlins/cool.gif
Yes, the oil will bypass the filter if the pressure gets too high. I don't remember the figure off the top of my head though.
swe_gvr4_1991
Sweden, Alingsås
Oil filter and pressure info for future reference:
The relief valve will crack open at 78 PSI (5.5 bar) according to the manual.
If oil pressure is 10-20 PSI at idle it can reach 80+ PSI by 7000-8000 RPM.
Old school rule of thumb is 10 PSI increase for every 1000 RPM. If it goes sky high at mid RPM there is a problem.
And if the oil filter burst coz of boost pressure there are serious problems with exhaust gases passing into the block. Rebuild is required.
Nice to hear that your new build came together nicely! /ubbthreads/images/graemlins/smile.gif
Brianawd
Portland OR,
A few things you can do.
1. go to a early style oil filter housing that does not have the oil cooler. Use a external.
2. pull the oil filter housing apart and put new seal and then torque to spec.
3. build the bracket that was posted.
I has a few filters come off due to the stub coming lose. I pulled the oil filter housing off. put a new stub and oring in. torqued to spec. Then built the brace. Never had a issue after that.
