bazeng
Update:
17-07-2012
Some new bits:
- Moran 2350cc injectors
- EGT 4 channel kit
- Driveshaft hoop
Completed:
- Exhaust - dump pipe / screamer pipe / cat - fully tig welded.
- Exhaust manifold EGT bungs welded in.
- Exhaust manifold ports have been port matched to the head / gasket.
- Exhaust manifold heat wrap half done (not fun with the fibres flying around). The titanium wrap doesn't require water.
- Turbosmart PROGATE 50 disassembled and re-orientated to meet new hose fitting locations. Spring pressure is 17psi.
Still required:
- Die grind bits and pieces to clean up the exhaust internals after the mig / tig welding.
- Purchase more heat wrap
- Coat exhaust parts
- Heat wrap remaining exhaust parts
- Fit all parts
- Mount oil cooler
- Wire up EGT box to Motec SDL
17-07-2012
Some new bits:
- EGT 4 channel kit
- Driveshaft hoop
Completed:
Still required:
- Fit all parts
- Mount oil cooler
