Quoting SmoothCustomer:
Somebody (curtis) should make trays with tie downs that mount conveniently in the trunk for dry cell batteries like this:
Click
I would but not to many people like those lawnmower batteries. I being one of them. Track car may be fine but I know of 3 or 4 cars that had those little turds and always had weirdo problems. One was a bumped compression evo with a buch of upgrades. Had drivibility issues as well as starting problems. sad when you have a 40K+ evo and makes over 700 to the tires but can't start and burnt up 2 factory starters before he realized I was right. Put in the big red top and has zero problems.
Now for the guys with batteries in the trunk or guys planning on putting them there.
Please for the love of God run another cable from the ground back up front. To optimize an electrical system for a stereo people will run huge fricking wires from there battery to the amp but leave the stock wires on the battery and even smaller wires from the alternator. But will put an upgrade alternator on. /ubbthreads/images/graemlins/banghead.gif Think use the brain . /ubbthreads/images/graemlins/banghead.gif
Best way to do it is take on of those screw in lugs from auto zone that go in the side post gm batteries. Find a hole with a nut welded on the backside of the firewall or fender well and drill out and re tap to that size. Then for the 12volt pos buy a distribution block/bus from a stereo shop that has a piece of phenolic resin or heavy teflon/abs to separate from ground. Get all this mounted nice then start running cable.
First huge 2-0 from distribution block to starter. Then another factory cable or a huge from alternator to little fuse block piece on the top of your battery now. I think there's 2 or 3 fuses on that piece. Now run a huge cable from the 12 volt block in the inter fender well through the big rubber plug up next to the top of the door and into the car. Run this down under the carpet and around the corner of the backseat into the truck corner.
Next is the ground side. Run it from the battery to thew trunk floor and find a place to connect it. Then forward stopping at any and every bolt hole you can find until you hit the side post deal you bolted on. You can daisy chain them or find the crimp on lugs that can be opened up and just strip out a section of insulation and attach as you go. Now that its upfront get a ton of ground wires or one of those kits on ebay and run grounds everywhere. Don't forget the t body, trans, cas, head, intake manifold, valve cover, mount next to the alternator. Etc.
Reason being is copper flows about 7 or 8 times the amount of current than iron or steel. The guys with a battery in the trunk and only a ground to the floor are hurting gas mileage, giving weirdo problems and not optimizing the system. cause back there you have one thin piece of sheetmetal with maybe 10 spot welds and a ton of seem sealer to flow around.
If you want to not believe me and aren't scared to do math click below. Maybe that will change your mind.
resistivity click me
By just adding a bunch of ground wires. My wifes Honda passport picked up 3mpg on the interstate and her next truck the xterra picked up almost 2mpg. Now the VR4 didn't matter but I did see alot faster starting, better driviblity and alot of idle wub wubs went away when I did all mine.
Anymore to this you could had a big circuit breaker, battery cut offs, then larger wires to fuel pumps and hidden switches going to the fuel pump relay, ignition transistor, etc as an anti thief device.
As for the wire bigger is better but don't get home wiring with 8 or 10 strands get welding cable from a farm supply or some of the sexy oxygen free stereo cable. I used stereo stuff mainly because I had it. The city had an auction and I was helping them by cleaning out the cars. The cops got sick of me bringing them more and more stuff to log in as the setup day went by so they told me to throw it all away. I had the trunk of the vr4 full of drug dealer stereo install kits as well as 4 amps one being a memphis bell class d. Lets here it for law enforcement. /ubbthreads/images/graemlins/devil.gif
EBAY LINK for ground kits
