This sneaky-Pete is stock appearing on the outside and all business on the inside. Featuring the 44 lb/min performance of the TD06 20G compressor wheel and a clipped TD05H turbine wheel in a 7cm2 nozzle area turbine housing, this turbo comes on hard and will set you back in the seat. To reduce boost creep, the turbine housing must be ported and is included in the price of the turbo. If your engine/application is heavily modified, Blouch Turbo recommends an external gate configuration to maintain proper boost control or upgrading to the TD06H high flow turbine wheel to reduce exhaust manifold/turbine housing backpressure. The Eclipse TD05H-20G is based upon a brand new genuine Mitsubishi turbo direct from Mitsubishi Turbo North America and requires no modification (internal gate version) to intake, exhaust, oil and coolant connections for installation.
