To Andrew. Thanks for selling me a transmission that does not shift into gear when the motor is started. It may have worked for you but it DOES NOT WORK for me. The mechanic that did the install is a Mitsubishi certified mechanic and has worked for Mitsubishi auto centers for over 9 years. I had your transmission swaped along with a new 2600 clutch kit which included the bearing, pressure plate and disk. I was there when he bled the system 3 times and it didn't work. He also went over the whole clutch system and found zero leaks and the clutch was operating perfectly. I have tried to be reasonable about this and give you every option to come over to my place and get it going. I have waited from my call 1/6/08 telling you that the transmission will not shift and you telling me twice that you would send the brackets that were never shipped and now you are saying that you need to locate them? What happened to the one that you brought when we made the exchange in Tomah? You put the transmission in the back of my car but never the bracket. If this was a couple hundred bucks I might have just wrote it of to bad judgement. But $1500 for the tranny and I gave you $50 for meeting me half way is TOO much to loose. Also the amount of money I spent on the install and the mechanic trouble shooting the transmission to figure out why it does not work.. his opinian is a bad transmission, yours is that it needs the other brackets. Either way I have spent alot of money for parts and labor for a car that does not run. Now you are saying you never gave me a warranty with the transmission and that you never said it would work unless you installed it. I suggest you check back on your first emails because that is what I will be showing the judge. I have had such good luck buying and selling items on this site that I got lazy. My mistake started by trusting you as a member and I did not get your full name and adress. ANYBODY WHO HAS DONE BUSINESS WITH ANDREW4G63 AND HAS HIS LAST NAME AND ADDRESS PLEASE EMAIL IT TO ME. It will be completely confidential. My email address is [email protected] Sorry Andrew, I really did NOT want it to go this way. Also better check your earlier emails to my questions about the transmission before claiming no warranty. Damit anyways,
Bruce Chapman
Bruce Chapman
