Aluminum o2 housing.
Status
Not open for further replies.
kcpaz
Gilbert, AZ
Whatever dude, you obviously aren't the type to listen to good advise, or even accept technical information. You think you can justify what you built because you've seen pictures of something, or because you saw it on some drag car that only has to run for 10 secs at a time. I don't know why I even bother. Good luck with that and be sure to let use know how "well" it works and how much weight you saved vs. the hassle of having to redo everything when this falls apart on the side of the road... /ubbthreads/images/graemlins/devil.gif
EDIT: you started your post by simply stating "Will it survive?" but you don't want to hear when people tell you it won't... so why even post it?
being rude is not a very effective way to give good advice.
it probably makes you feel cool though.
steve
NJ
Quoting TrendSetter:
what if i wrap it in header wrap?
Now you're just trolling. /ubbthreads/images/graemlins/lockd.gif
Status
