AC delete How-To?
3Diamond
Vancouver
Woow, you guys are taking AC out, as i am trying to get mine IN! There are models that came with ac, but if youre deleting it, you could do what the owned did to me galant, he/she/it simply removed evap box, remove 3 metal clips, take evap out, and return the now (super) light box back in. Heater funstionality restored! The previous owner used some sticky tape to cover the holes left over from AC. Althoiugh i dont think tape should be used on them; as there is probably a factory solution.
Which reminds me..if anyone has a GOOD AC front condensor fan, and one of those ac temp switches that mount on thermostat housing LMK!
Yao
Denver, CO
If you are lucky, you can find a none AC galant in the junkyard and find an OEM piece that goes where the AC core would be. I've done it on my Eclipse and it is completely factory.
CP
West Simsbury, CT
Ah, good idea. Off to the junkyard in the next week...after all the local ones dry out for a few days. I'm sure they're mud-central this week.
for the Non-AC plug if you remove your evap look on parts.com under Galant NON-AC... Its an $11 part.
I don't really give a rat about future owners, if I ever even decide to sell it.
Is that any way to treat KC? /ubbthreads/images/graemlins/tongue.gif
/ubbthreads/images/graemlins/rofl.gif /ubbthreads/images/graemlins/rofl.gif
If you sell your car OF, you better not leave here either.
CP
West Simsbury, CT
I'm not selling the car anytime soon. I just want to retire it from daily driving within the next year. When we move into the next house in a year or two, I'm pushing for a 3 car heated garage.
CP
West Simsbury, CT
Condenser and all the lines are out. Same with that canister in the driver's fender. Tomorrow I'm going to have a go at the compressor, and will hit a local junkyard to see if I can find a non-AC car with the stock gutted evaporator box. Otherwise I may try to do it myself.
My system was empty of refrigerant, so we must not have gotten everything tight last May when the engine came out. Because the AC worked just fine before that, as well as the few times I used it last summer too.
s_firestone
Park City, UT USA
Pulling it is not too bad. You will want to put some thought into blocking the two gaping holes in the firewall one right beside the fuel filter and one down lower for the AC drain. I think the cover will assemble without the evaporator fine. While your there good time to clean all the leaves out and consider a cabin filter. Come to think of it, that would be a great location for a water injection tank.
CP
West Simsbury, CT
By the stock fuel filter there are two holes in the fitting that passes through the firewall (one bigger than the other), which I plugged with some rubber caps pushed in backwards.
AC drain? I didn't see that one. Where exactly is it?
s_firestone
Park City, UT USA
About an inch above the bottom of the firewall/pan to the left(from the inside) of where the A/C lines pass through. The drain(plastic) exits the hole and turns straight down, and comes out just to the passenger side of the driveshaft(about 1/2" clearance). You may have to reach and feel for it. I think the drain gets easily obscured by padding from the inside. There may be a hole on the back of the evaporator housing where it comes through. Once the evaporator comes out, it comes out real easy(and may have already fallen out).
Cy-one thing I did not see mentioned is the compressor bracket.It also acts as a spacer for your axle support bracket that bolts to the block.When I removed my bracket,I cut the ear off and installed it behind the axle support.It's fairly easy to do,just thought I'd give you a heads up.--Jeff
Anyone have some pictures on how exactly to do this? or before and after pics.. I'm not sure of these parts you guys speak of.. Condesor?
Rausch
Cleveland, OH
Thank You.. Soo i shouldn't have any problems if i remove all of that stuff? I really dunno what i'm doing when it comes to a/c removal..
FlyingEagle
THE Ottawa
If I had written one earlier, my point exactly. ^^^
Unless you absolutely need the space ... Oh hell, you don't and you can keep AC in the car even with 800 HP, just be gentle when it's on and don't drag with it turned on, even though there is a cutout feature likely near the 5k mark to save the compressor internals. /ubbthreads/images/graemlins/devil.gif
If you have to remove the condenser, compressor and exterior lines for temporary drag glory, I could see doing this, but keep the dash stuff intact and properly capped. You can have AC and still have proper cooling factors, just be sure to get "good", big fans and duct that front end.
mitsuturbo
Near Seattle, Washington
Quoting GSTwithPSI:
Don't remove your A/C. You'll be old someday, and regret it.
I'm old.
I drove my car to work and back yesterday.
I do not have AC.
I spent an hour in traffic with all 4 windows down and the sunroof wide open.
NO RAGRETS
