93 Eagle Summit Wagon AWD project
Leon_R
Chelmsford, MA
If you want to weigh your car, you need to go to NED on the weekend /ubbthreads/images/graemlins/frown.gif. That was the main reason why I attended last Import wars. My van was 3010lbs.
My guess is that your wagon is 100-150 lbs heavier.
Nice RX7! Though I would prefer a droptop /ubbthreads/images/graemlins/wink.gif
CutlassJim
Manchester, NH
Quoting Leon_R:
I weighed mine on a Wednesday street night. When I went the next Friday though the scale was closed. /ubbthreads/images/graemlins/dunno.gif I can't believe that little thing only weighs 40lbs less than the 2G. My van must be a porker.
Quoting Leon_R:
Good thing you don't have to drive it. /ubbthreads/images/graemlins/wink.gif
Leon_R
Chelmsford, MA
Quoting omertaitalia:
what does the wieght on your vin sticker state?
I am not sure, not that it matters, that is your total, loaded weight (5/7 passengers, luggage, full tank).
Jim, they almost never leave scale open on Wed. night. Must have been a left over from the track rental from the afternoon.
Leon_R
Chelmsford, MA
Well, my 3 door Summit was around 70-80 heavier (just shy of 3100 lbs) when stock. It dropped the weight after the swap because I removed:
Front bumper
Battery went from 40 to 16 lbs
AC system
EVAP system.
Also, before getting my Summit on the scale, I was hearing all sort of "stories" about it being around 2800lbs. Those weren't true, or people didn't mention some weigh savings. You really will just put yours on a scale to be sure (or get Jim to do it).
CutlassJim
Manchester, NH
Did the 3 doors with ABS also get the rear discs? I mentioned it before but my van and I'm assunging the 92 has a ride height based rear brake bias like the MightyD50's that I don't think the small ones do. I might have a work trip to J-pan coming up would you be interested in any RVR parts?
Leon_R
Chelmsford, MA
I wish my van had ABS... Not because of ABS, but because of rear disc that came with it /ubbthreads/images/graemlins/wink.gif. And yes, 3 door vans had the same ABS/disc set up.
fuel
Toronto, ON, Canada
what rvr parts fit on our 7 passenger van? ive never really seen them.
The RVR is the JDM equivalent to the Expo LRV 4 door/4 seat vehicle. In Japan the 5 door/7 seater is the Chariot or the Nimbus in Australia. In Japan the Chariot also comes out as a 'GT' with the Evo1-3 7 bolt engine (detuned with 450cc injectors and TD04 turbo) and AWD. One of the RVRs I've owned had allow front lower control arms which looked to have the same mounting points as the E39A VR-4 but just being cast alloy instead of pressed steel. I've been meaning to get them side by side to see if there are any caster differences like between GVR-4 and 1G.
omertaitalia
Downtown Los Angeles CA/Lake Tahoe,CA
i also saw that in europe it was sold as a hyundai,and in japan it was called the space wagon, i read a thread where a guy swapped out the rear disc brakes from a galant and put it on his expo, leon said its not possible but the thread i read was a 92 7pass. van and he said he just swapped it right out. have yet to see if its possible.
fuel
Toronto, ON, Canada
in Europe the 7 seater (Chariot) was named a Space Star while the 4 seater (RVR) is a Space Runner. The Space Wagon was C10 Mirage/Colt based, and then the Space Star name was later applied to a European only model built in the Netherlands which shared the same platform as the Volvo S40/V40 and Mitsubishi Carisma.
Old Top Gear video here - click
I'm trying to remember what the Hyundai version was called, but they were sold in such small numbers in comparison to the Mitsubishi counterparts.
Leon_R
Chelmsford, MA
In Korea, they have a LOT of Hyundai' Space Wagons!
I would LOVE to get my hands on RVR Sportgear:
- seats
- 5 lugs hubs
- rear discs
- rear LSD
- hood
Just to name a few /ubbthreads/images/graemlins/smile.gif
But I see no economical way of doing this. There is a guy who is parting one out in Australia, he was willing to ship the rear hubs to US, but shipping would have $250!!!
fuel
Toronto, ON, Canada
Quoting Leon_R:
- seats
- 5 lugs hubs
- rear discs
- rear LSD
- hood
But is
That's the Super Sports Gear, the Hyper Sports gear has a front mount intercooler and different bodykit and the MT versions get the TD05 with large compressor housing. The regular Sports Gear is non-turbo without an LSD and vented hood but does have 5 stud bits and nicer seats.
I've owned a '91 RVR-R 6-bolt/4-lug 5spd, a '92 RVR-X 6-bolt/4-lug auto and a '93 RVR Sports Gear 7-bolt/5-lug 5spd.
Leon_R
Chelmsford, MA
the hyudai was sand sumin cant remember either
edit:hyundai santamo
Whatever they were called, they were ALL OVER the place! Including being used as cabs /ubbthreads/images/graemlins/smile.gif
89Mirageman
Stantonsburg, NC
There was a 5 door awd auto wagon at the local junkyard with abs/rear discs but I already pulled them for another guy. To me they looked very similar to 2g dsm parts or 94-98 galants. The backing plate holds the caliper on and the rotor has a hat with small shoes in it for the ebrake. There is a 94 Galant GS at this same yard if someone can verify they will fit I can grab them. I can tell you for sure that you have to press the rear hubs out to get the backing plates off. On the awd's of course.
